Compression?
Dobb15
Just wondering what is a good compression for an older motor on a Boat ?? Checked mine the other day and i had 100 in one end cylinder and 90 in another!!
bruceb58
Re: Compression?
How about the other 4?
How did you do your test? Engine warm? Throttle all the way open? At least 4 compression strokes?
Re: Compression?
Ayuh,... Those #s are Tried,+ Dead.....
Dobb15
Re: Compression?
Yea i thought it was tired, 140 is good ?? i plan on a rebuild this fall ... i tested it for 4 pumps but not throttle open or engine warm?? does that make a difference??
Don S
Re: Compression?
The engine doesn't have to be warm, but it shouldn't have been setting for months or years before doing the test either.
45Auto
Re: Compression?
Throttle not being open can make a HUGE difference. Hard for it to compress air for a compression check if it can't suck any in past the throttle butterflies .....
