compression
cblguy4u
Hey does anyone know what the compression should be on a 1967 evinrude 80hp? thanks for your time.
JB
Re: compression
All four should be withing 10% of each other.<br /><br />Actual readings will vary, depending on technique, engine temp and the particular guage you use. Minimum should be 90 to 100 psi.<br /><br />Good luck. :)
