computer to TV cord
rbh
Does anyone know what cord is required to go from the computer to the tv?
just looking to get the video signal to the bigger screen.
thanks
rob
RollingWanderer
Re: computer to TV cord
That depends.
1 - Is your computer a desktop or laptop?
2 - If it's a laptop, does it have a standard VGA (15 pin connector) monitor output?
3 - What type of TV, older CRT or newer flat screen?
4 - If a newer flat screen, does it have a standard VGA monitor input?
If you can answer a desktop or laptop with VGA output and newer flat screen with VGA input, then all you need is a standard monitor cable. If not, then it's gonna be a little more complicated.
-RW
roscoe
Way to many possible combinations to guess.
Most newer tvs will have either a vga or a hdmi input, mine has both.
We use a DVI to hdmi cable to hook up to the tv.
We use a DVI to vga cable to hook up to the older monitor.
rbh
Thanks guys, will look into input and output jacks/plugs that are available on the equipment. :)
BoatBuoy
I got that idea a while back. First I tried the VGA connection and it produced a lousy image. I then borrowed the HDMI cable from my BlueRay DVD and used that. My laptop has an HDMI output. The image was outstanding.
Gary H NC
The graphics card in the computer will determine picture quality too.
jay_merrill
As stated, it depends on both the computer and the TV. I've been building a multimedia center, but haven't bought a flat panel TV yet. I am currently using a digital ready CRT television and obtain signal from both a digital broadcast antenna and an S-Video connection to my media server graphics card.
The S-Video output on the graphics card will treat the TV as just another monitor, so you just have to enable it in Control Panel. In terms of the "monitor," my system is still a bit crude, but it works for now and I want to put a second HD and a TV card in the Puter, before deciding on a screen.
rbh
rbh, I use <ncix.com> for cables etc. Prices are good and they're in Vancouver.
Hey thanks Mike I will look into that store as its in the lower mainland, I bet you and puddle jumper are getting a ton of rain this week, here in the north Okanogan its +2c, and the snows sliding off the roofs, yaaa.
rob
Mike Robinson
Actually it's been quite dry here for the last month or so and it's sunny today but there's rain in the forecast.
Tacklewasher
rob
NCIX is good if you need online, but if you are going there (or coming to K-Town), make sure you know what you want and hit Princess Auto first. If they have what you need in the surplus section, it will be a lot cheaper than anywhere else. It's the only time I will buy (usually way overpriced) Monster cables. Just can't check what you need online.
