Condener Keeps burning up?
KaGee
Re: Condener Keeps burning up?
Yea CC, I'd say you are right. My 28 years in the electronics industry, selling electronic components (resistors, CAPACITORS, semiconductors, relays, switches... etc.) don't stand up a lick next to your professors.<br /><br />When Wilee's problem is fixed, then the thread will be done. Personally, I wonder if he has two problems. The high voltage being one of them. The blown capacitors being a second. I do not know for sure that they are related. The capacitors should be rated high enough in voltage to handle the 16 plus volts.
rodbolt
wow I cannot resist but if you use a peak reading meter on the negative side of the coil primary you will see an amazing voltage. most all of the PCM engines made by ford that had points used a ballast resistor, this is a special wound wire in a ceramic housing that as more current passes through it it generates more heat and the resistance goes up to limit current hence dropping the voltage to the coil positve primary. as its been stated all an ignition coil8s is a step up inductive transformer. the condenser on the point absorbs the excess voltage generated by the collapsing magnetic field that will cause more arcing acrossed the points. arcing is like welding:) :) ><br /> with the engine running a standard VOM will not read true voltage due to the internal circuitry of the meter. at high speed this will act almost like an ac voltage. remember capacitors and condesers can pass ac and block dc. <br /> you can also charge them up on the snap-on ign simulator and toss them to your buddies :) :) .I agree that I think your fighting two problems. I would first repair the charging system and then try to find a bad ground on the breaker plate.<br /> good luck and keep posting
steve n carol
all you guys, thats good stuff.<br /> I don't think that this thread is "beat to death" I'm still learning here!..sl
Boatist
Kagee<br />If you use the condenser for radio noise suppression (filter)it will go on the plus side of the coil. You do now want to put it on the negative side of the coil. The condenser in the distributor is on the negative side of the coil and is a specific size to control points arc and supply current to the coil primary. Condenser for a standard 4 cylinder is .18 to .23 Microfarad and for a V8 is .25 to .29 Microfarad.
Boatist
cc lancer<br />You need to get your professors a book called electronics 101. A capacitor is the most common filter used in Radio, TV, Computer and all electronics. Even today with advanced circuits almost all power supply have two capacitors on the output one to store the power and one small one to effectly short spikes to ground. Go to Radio shack and buy a filter for your car radio. You will find it is a very good L C filter. The coil stops current spikes and the capacitor stops Voltage spikes. <br /><br />A ballast resistor and resistance wire do the same thing. The Ballast resistor is just a resistor put in a ceramic block to help disipate the heat so the resistor does not burn up. The Resistance wire does the same thing. It is a low resistance wire that spreads the heat out over it length to keep it resistance from burning up. Both reduce the current and drop the voltage to the Plus side of the Coil. The voltage is reduced from 14 volts down to about 9 volts.<br /><br />A 57 chevy has a capacitor on the plus side of the coil to help filter out electrical noise. Chevy used a capacitor on the plus side of the coil up until the electronic ingition came out in about 75.
KaGee
Glad you are learning Steve.<br /><br />Thanks for the support Rod and Boatist. <br /><br />I figured no sense in arguing about it. After all, I'm just a backyard hack. ;)
cc lancer
KaGee: I stated in my post if I was wrong I would apologize, here is my apology, I could not understand how a condensor filtered since it is on the cranking side of the circuit. See attached letter from Mr. Jim Lux, Senior Engineer with NASA.<br />"Well...<br />The capacitor does prevent arcing at the points. As the points start to open, the voltage across them starts to rise, if there's no capacitor, and you "draw" an arc (much like arc welding). The capacitor delays the start of that voltage rise a very short time, but long enough for the points to actually get separated far enough that a spark can't form.[interesting side note... voltages below about 300-400V cannot jump a gap, no matter how small, so the cap doesn't have to delay the voltage rise very long]. If there's no spark, there's much less erosion of the points. Actually, if the cap's not there, the arc dissipates the energy stored in the iron core of the ignition coil, and the sparkplugs won't fire...oddly, a failed ignition capacitor (condenser) almost made my father late for his wedding, and had that been the case, perhaps I wouldn't be answering your question now...<br /> <br />As far as RFI goes. If the capacitor wasn't there, you'll develop the spark, which will suddenly quench as the points get far enough apart. The sudden transient has significant RF energy, and since it's on the low voltage side, it's connected to all the 12V wiring in the car, so it has a good antenna (if not an actual wire leading into the radio through the power). The HV side (the sparkplugs) cause less interference because the wires are shorter, and there's resistance in the lead which slows down the speed of the voltage rise, reducing the RFI. In the case of the spark in the cylinder, it quits because the coil has run out of energy to put into it, so it has a "softer" falling edge, which makes less RFI.<br /> <br />To sum up... the cap reduces the RFI, but not by bypassing the RF to ground, but by making the ignition system work like it's supposed to."<br /><br /> <br />----- Original Message ----- <br />From: bennie cox <br />To: jimlux@earthlink.net <br />Sent: Saturday, September 11, 2004 7:35 PM<br /><br /><br />Dear Mr. Lux:<br />I would greatly appreciate your opinion on the following subject.<br />I am in a debate with a gentleman concerning the condensor in a 1979 boating application.<br />He says the following "The capacitor buffers the spark on the points, keeping them from burning up prematurly as well as filtering the DC power line reducing ignition noise in radios and other marine electronics."<br />I say the condensor does nothing to suppress noise in radios and other marine electronics. In the 50 years I have worked on internal combustion engines, I have never read any thing stating that the condensor in a distributor, suppresses noise in a radio. Your opinion would be greatly appreciated.<br />Sincerely:<br />Bennie Cox <br />Mid Atlantic Marine<br />Yanceyville,NC<br /><br />Boatist: Your comments of 9-11 was not at all appreciated, and clearly written to degrade me. I went to a Junior college in 1968<br />and studies electronics. As I stated, my hobby is pinball machines, I am very familiar with filtering capacitors, all of the machines that use voice chips must have clean voltage or the sound will be distorted.<br />Since I am new to the forum rest assured with 50 years experience with internal combustion engines, 12 years in NASCAR racing and 35 years in all phases of the marine business,[repair, reconstruction, consulting, and brokerage] in the future I will extend the same courtesy you extended to me.<br />Regards<br />Bennie Cox <br />Mid Atlantic Marine
airman
Just to add to the confusion, my last boat (w/'72 Chrysler 400's) had block style ballast resistors on them. I never thought they might pose a hazard but I'm pretty sure they were OE.
DHPMARINE
I'd clean the condenser ground and the distibutor ground.<br />DHP<br />Oh yeah many sterndrives had ballast resistors stock.
Boatist
CC Lancer<br />To start with welcome to the board. I think we can agree to get along. Reason I wrote what I did was you came down pretty hard on KaGee and much of what you said was inaccurate. I have found not a good idea to use NEVER or ALWAYS.<br /><br />You will find many on the board know ther stuff. Like you I am a old fart now. I took my first Electronics class in 1963 as a High School Freshman. Built two CB walki talkie a tube CB radio as class projects. Taught part of the same class in 1964 as a student aid. As a class project I built a 250,000 volt Tesla Coil from scrap parts. As a senior rewired my parents house. After high Joined the Air Force and went to a 6 month 8 hour a day electronics school follow by a 6 month computer school. Been working in computer ever since. In the old days repaired everything right down to the componet, (resistor, capicator, transister, diode, tube). Today not much fun as all we do is swap out major assembly. I am the only guy in our shop that can use a oscilloscope, signal generator, signal tracer, logic analizer and many other tools of the past. Also been a ham since 1972. As far as boats go I got my first boat when I was 15 and still have that boat and another boat I got in 1980. Have always done all my own work. I also have done all my family auto work since 1965.<br /><br />Anyway nice to meet you and I am sure we will agree sometimes and disagree sometimes. <br /><br />I hope Wilee will come back and tell up what fixes his voltage and Condenser problems. I hope he fixes the voltage regulator/alternator before he burns up an expensive iteam.<br /><br />Quotes I disagreed with below. <br /><br />"The condensor/capacitor does one and only one thing in an electrical circuit, it stores energy [electricity], this energy is released by electrical components, or a mechanical device [points]. It cannot, will not, never will control electrical spikes in a circuit, [static]."<br /><br />"It cannot, will not, never will control electrical spikes in a circuit, [static]."<br /><br />1. Capacitors do control electrial stikes and also store energy.<br /><br />"A ballast resistor is not used on a boat for two reasons, they get hot, and with an extreme failure the potting material breaks away and there is a red hot wire, and possibly a spark, therefore the resistant wire is used in the circuit."<br /><br />2. Ballast resisters have been used on boats.<br /><br /><br />"People get overly concerned about voltage....amperage is what will kill you."<br /><br />3. I will grab both sides of a 200 amp 12 volt battery if you will touch the 10,000 volt ac line behind my house. True it may be the amps that kill you but it takes the voltage to push the amps thru the human resistor.
KaGee
Spoken like a true Californian!<br /><br />"Let it all hang out!"<br /><br /> ;)
cc lancer
Truce<br />Boatist the only reason I am on this board is to help people. I am sick to death of boat owners getting ripped off by unethical people who prey on the ones who is not informed.<br />Out of war friendships are bonded and I hope that applies here.<br />I started handing my brothers wrenches around 6 years old, and by age 10 I was spending Sat. mornings at garages, sweeping floors, listening and learning. By age 13 I could rattle all the parts of a small block Chevy as fast I could talk including specs.<br />I have always been fascinated by all the power that can be produced by these engines. Ironically I studies Accounting and law in college, then I was paid to take the electronics course, to help 4 guys that worked for the telephone company.<br />3. I will grab both sides of a 200 amp 12 volt battery if you will touch the 10,000 volt ac line behind my house. True it may be the amps that kill you but it takes the voltage to push the amps Thur the human resistor<br />KaGee, do not grap the 12 volt battery it will stop your pace maker.<br /> :D :D <br />Back to topic, I am going to start another thread on the lowly condensor, the more people that I asked about it, the more questions that were raised. Some were the old Grand National guys[pre Winston Cup]that said that points ignition were always a pain in the butt. They would put in a new coil, points, and condensor, after each race. As we both know condesors/capacitors "wear out" with age, it always amazes me that a new cap kit can bring a video monitor back to life.<br />Yes I agree old Farts agree and disagree and sometimes everyone learns something.<br />The next time I put my foot in my mouth, I warn you now I will enlist the help Of James Carville to help get it out. :)
KaGee
PACEMAKER???? YIKES! :eek: <br /><br />No harm, no foul on this end.<br /><br />I want to know, what voltage these ignition capacitors are rated at. I would think at least double the line voltage...say around 25 volts. There are no markings on the ones I have around here.
Boatist
KaGee<br />I not sure what the voltage rating is either. With Capacitors normaly double the maximum expected voltage. This is one place where going to too high a voltage is not a good idea because it will increase the size of the capicator. I looked a couple of places and have found no voltage rating.
