confirmation of fiberglass/resin choices for old Glasspa Stringer and Deck repair
Mikeopsycho
I rolled on gelcoat with crushed walnut shells for non-skid. Just throwing it out there as an idea.
ianmoore
No Title
Thanks Mike. I went with Interlux brightside 'kingston grey' with some Silica sand.
I actually finished the CSM deck wrap today. Man was that a job. I was gonna try to do the glass multi/layer one area at a time, but I had a tough time pulling it off. I ended up doing a layer of CSM, letting it cure, then coming in and lightly grinding some high spots/bubbles, etc. I did the second layer and will go back, doing another light grinding and probably a few patches. Once that is cleaned up i will do a final layer of 6oz. As I said above, i will be painting the main deck with the interlux brightside.
Here is a pic of the end of day work. The seam towards the back is a piece of 1708. I ran out of big pieces of CSM. I will still cover everything with the 6oz, and this back part will be under the splashwell and the rear seat.
ianmoore
No Title
And finally the cloth! Deck is wrapped and next up will be deck paint!
ianmoore
No Title
First coat of primer on deck, plus primered splashwell. I will be painting up the inside of the hull as well, but i am doing it in steps. The deck itself will have some silica sand
ianmoore
No Title
I did a second coat of primer on the deck, did some fairing on the splashwell and transom, and did a bunch of sanding on the hull. Somebody had splashed some paint on it to cover up some fiberglass showing through the gelcoat, and this was taken off as well. I have a friend who used to Gelcoat for a living. He has offered to help me re-gelcoat the hull. I will do it to the chine.
More sanding and priming for now.
ianmoore
No Title
Transom is almost faired. Probably one more pass. I'm also working on the splashwell..Its almost done. I put another coat of primer on today. Looking to start painting it in the next couple of days. I also started working on the fiberglass piece that goes in the cuddy. I'm going to repaint it as well. I patched a couple of fiberglass tears and will do some fairing on it, and then paint.
Also started cleaning the seats. If i had the money i would reupholster, but for now I'm just cleaning them up, cutting some new plywood and re-installing.
ianmoore
No Title
I painted the deck, 2 coats, and inside hull(one coat) today. Here is after the first coat. Interlux brightside 'kingston grey' with some silica sand non skid.
A little more fairing/fixing on some of the fiberglass inside parts. I'm using a light blue Marshall's cove paint for the dash/cuddy parts, as well as the splashwell
ianmoore
No Title
Fairing, fixing, sanding, priming, repeat
fairing, fixing, sanding, priming, repeat......
I've been doing a bunch of cosmetic work on the interior pieces(splashwell, dash, cuddy inset). This boat originally had the steering on the port side, so switched that. The splashwell below is one i found at my friends boat yard, and required a good deal of renovation. I think i'm finally saying its done and ready for final sanding and painting. I painted the cuddy insert first to see how the paint and application would hold up. I'm pretty happy with it! I'm using the Marshall's Cove paint, which is an enamel based single stage. It came highly recommended. I was originally going to roll it on, but with all of the curves and indentions in these pieces, i decided to use a Prevast sprayer. After a couple of passes i got the hang of it. I did really light coatings with repeats every 15-20 minutes until i got to what would be a solid "first" coat. This is what it looks like. I am going to spray the splashwell today, as well as the two dash pieces.
If i have time, I'm going to take a stab at rolling some gelcoat on the transom. this will be my first try and I've been reading up on the process. I figure if i screw up its a small enough area that it won't kill me to start over. My buddy comes over next week and we will gelcoat the hull.
In all of the fairing, i went through a couple of products. I really like the 3M Marine premium filler. It is easy to use, sets up quickly, and has made my fairing/sanding go a lot smoother<g
ianmoore
No Title
I have all of my insets finished and painted. I glassed in the cuddy inset and cut a new bulkhead for it. The floor dimensions changed with the new floor, so it took a little bit of maneuvering to make it work. As i said earlier, the steering was on the port side, so i will be switching it to the starboard side.
I consider my first attempt at gelcoating to be a success. I put on 3 layers, sprayed some PVA, had to sand an acetone as i needed more thickness, and added 2 more. I'm now wet sanding, and it's coming out pretty nice. I applied the gelcoat with a roller and it went on OK. I think when i do the hull i will try a slightly different roller and also tip as well to minimize the orange peel as much as possible. I did a bit of research on sanding procedure for new gelcoat, and will probably try using an orbital on the hull to get to a good wet sanding starting place.
I ground down as much rust as i could on the seat brackets and repainted my rust inhibitor. This is somewhat of a funds inspired temp solution, but should hold up for a couple of years. The vinyl on the seats is nearing the end of it's life, but will make it through the season.
Now that i have the splashwell done, I can fit in the ply side pieces and test fit it into the hull. this type of splashwell had vertical mahogany pieces that connected it to the hull via a glassed in horizontal piece. I'm going to test fit and plan that piece out here in the next few days.
Getting closer!
ianmoore
No Title
I used WOG's recipe for wood preservation before installing. Ground down the metal corner pieces. Nice and shiny!
I will install the gunnel wood in the next day or so and then i can install the Splashwell. This design has 3 vertical strips that mount to the deck. I have seen some designs on the old Glasspars where there is a glassed in board that they mount to. I'm trying to find something where i don't have to screw into the deck
Woodonglass
Honorary Supreme Mariner
Did you REALLY do the edges well? That's the most important part of plywood and then the full strength coats of Marine Varnish on the outside flat layers and edges too!!!
ianmoore
No Title
Woodonglass, I have studied sir! I applied the protectant thoroughly, focusing on the edges, let sit 72 hrs, and am now coating with varnish
ianmoore
No Title
Some more pics
ianmoore
It's fun to learn all of this new stuff, and in the process get a really cool restored boat. I have made more mistakes then i can count, and can see how it gets addicting.
you start to figure it out and think, "next time if i only"....
Willyclay
Multiple Boat Syndrome can strike anyone, anytime, anywhere! I peaked at three but am down to one which is probably my last. You are doing great work.
ianmoore
No Title
Latest update:
I bought one of the cheap Harbor Freight HVLP guns and did the mod to clean out all the silicon and reseal the threads. I had already trying rolling the transom, and figured i would give the gun a try as well. Full disclosure-I have never used a paint gun, much less sprayed gelcoat. I did watch a few videos, and spent a good deal of time prepping.
I tried the gun first with water just to get it's basic functionality down. Seemed ok. Mixed the gelcoat, adding about 6% styrene. First coat went on pretty well. Not sure what to expect as i haven't done it before, but thicker then when i rolled it. I was almost done with the second side of the hull when the compressor blew a breaker! Crazy running around, changed plugs/circuits and started spraying again. Timer went off(15 minutes) and dumped about 1/3 out for fear of it kicking. Cleaned the gun, mixed up another batch, this time at 10% styrene. Set timer. this batch kicked super quick and i had to dissasemble the gun and spend about 30 minutes cleaning it. I did get the whole hull sprayed before that happened. 3rd coat kicked slower and i was able to get a nice coverage. It started kicking, and i was able to pour off the remaining gelcoat and do some small cleaning. I was trying 16oz at a time. I'm going to do 2 more today with both being 12oz. Second one will have some wax in it. I'm going a little bit more heavy so i can not worry as much when i run the orbital with 220 to take off the orange peel.
Mostly looks good. A couple of bugs wanted to be part of it, but I would consider my first attempt a moderate success.
​It's messy!
ianmoore
No Title
Here is where we are at today. Inside deck is painted, and all of the wood is stained. I am still working on getting the orange peel down, so more sanding!!
I'm going to test fit the splash-well and install the dash pieces. Once the outside transom is sanded and buffed will put the motor on.
I'm going to order some gelcoat from Fiberglast with color to patch up some dings and so forth. I've been trying to find the best match
getting closer
