sutor623
Thread starter- Joined
- May 23, 2011
- 4,089
Hey fellas,
Just was wondering your opinion on engine break-in procedures. I had OBR rebuild my powerhead and was very pleased with their work, overall. I was reading over their break-in procedure and it varies greatly from the factory manual. Posted below is OBR's and Evinrude's break in procedure. OBR is saying this for ALL of their rebuilds, so I feel like it is generic, and VERY conservative. Just seems like they are protecing their own A#%!!
I ended up running thorugh 3-4 heat/cool cycles on the muffs (maybe 1 hour total run time) because I was working out some fine tuning and issues with quickstart before I brought her all the way to the lake. The good thing was that I could re-tighten down the powerhead mounting bolts after the heat/cool cycles.
After that, I pretty much stuck to the Evinrude guidelines. Except for the fact that they say for the first hour to hit the throttle and get the boat to plane, and just back down to minimum planing speed, staying under 3500 RPMs. (That was a contraindicitive statement for me, because minimum plane speed on my boat is 14MPH at 32-3500rpms.)
But Evinrude says to hit full throttle in as little as it's second hour of running, and OBR says to stay below 3000 rpm's for 6 hours!!! How could you do that and still vary the throttle position every few minutes?? You couldn't because you would keep hopping off plane.
Anyways, just wondering if you guys agree with me on just sticking with E-rude on this one? Thanks!
