craze1cars
- Joined
- Dec 26, 2004
- 1,822
Had my dash cluster loose yesterday, probing around with a meter to figure out why my voltage drop seems a bit excessive at the dash...but everything was running fine...voltage gauge reads about 11 at the dash.
With ignition ON, I put multimeter probes on "ign" and ground probes on the back of the volt meter. I accidentally shorted the two and was greeted with a very tiny little quick spark and the entire dash panel went dead. Oops.
I dove under the dash and immediately found a blown 5 amp fuse in the "ignition" slot. This looked like a little 5 amp spark to me. So I replaced it. While there I verified 12.6 volts at both sides of this fuse. Figured I was done.
So I went back up top and turned ignition switch back on. Nothing.
With ignition switch OFF, I have 12.6 volts when I put meter between the "B" (hot) probe of the ignition switch, and ground on the back of the volt meter. But as soon as I turn the ignition switch to ON, the voltage drops to ZERO. I cannot figure out why. When I move the red probe over to the "I" slot of the ignition switch, I still get zero volts. So now I'm thinking maybe I somehow shorted out the ignition switch?
I have removed the ignition switch and tested it for continuity. It is fine, and switches on and off like it should at the 3 terminals. I even temporarily installed it in my other boat and it fired right up no problem. So the ignition switch is fine. But I can't get 12 volts to go through it to turn on power to the ignition circuit on this boat.
I ran a jumper wire straight from the battery and touched + to the "I" terminal on the voltage gauge, and - to the ground on the same gauge. This energized the ignition circuit as it should. Yet I can't get it to work through the ignition switch despite reading a solid 12.6 volts right there at the hot terminal of the switch itself. And why does that number drop to zero the moment I turn the ignition switch on?
What the heck am I overlooking here? Very confused. Thanks for any suggestions for solutions or further troubleshooting methods if you have them.
