bart98stang
- Joined
- Mar 6, 2011
- 104
Greetings fellow boaters. I hope your boating season is going well. I need some help as I can't find my answer. I have attached two pictures of my 1990 Sunbird 194. The red gelcoat that's above and below the rub rail was extremely faded. I tried compound, wax, wet sand up to 2000 grit and I couldn't get rid of the oxidation so I completely dewaxed and applied rustoleum red marine paint (from Lowes) directly over the sanded gelcoat. I guess in hind sight I should've reapplied fresh/new red gelcoat but it is what it is. My plan was then to apply clear gelcoat. I've read a bunch of different forums and articles and of course there are different answers regarding how to apply the new gelcoat over where I just painted. The most common method I have read, in a nut shell is to spray 3 different coats. The first 2 coats with unwaxed and the 3rd spray with waxed and then sand to a shine. I'm thinking about going this route. I'm currently shopping for gelcoat and I've been finding some brands that are not even labeled whether or not it has wax in it and I recently found a brand that has the wax additive separate so it can be added as needed and I was like score this is what I need then it read to not apply directly over paint and it burst my bubble. Here is an example: http://www.bottompaintstore.com/gelcoat-clear-hiuv-p-10333.html
I'm entirely confused and in need of your wisdom, guidance and advice of what type/brand of clear gelcoat I need to finish my project and how to correctly apply. Thank you in advance for your time and assistance.
