Here is what wikipedia defines as marine grade plywood.
http://en.wikipedia.org/wiki/Plywood#Marine_plywood
The prices they quoted may be a little on the low side but the description is sound.
To add to this. Plywood use to be interior or exterior. In recent years they have started making all plywood with exterior grade glues. So in reality any good grade plywood will suffice for flooring. If you want to use a non marine grade look at cabinet grade plywood and by all means ask about the glue used. A supplier of same will know or find out. Marine grade plywood has become less than perfect. The best part of marine grade plywood was the absence of voids. I have seen this not be the case anymore. When cutting it I have seen voids when really there should be 0.
I see your point, marine is "treated" but it isn't treated like you buy at home depot, they aare different but the marine ply still has been treated with chemicals to keep growth and decay in check.
Wood that has been pressure treated with the old formula is now also refered to as "marine" grade or use or type.
It is also the type recommended for below or on grade use.
So "marine plywood" is now also a term used for regular exterior grade wood plywood that has been treated with the old type preservative.
The consumer type treated lumber found in the big box stores is almost always the new type of treated lumber.
So when talking about "marine plywood" you have to be specific because there are so many variations of what is called "marine plywood"
Information given like this only adds to the confusion... please provide info of your above statement....
This is the information i am going by
http://www.apawood.org/level_b.cfm?content=srv_help_prd_marine
As far as i am aware any "pressure treating" of "Marine" plywood is done by a second party other than the original manufacturer. Because of newer EPA regulations there are different levels of pressure treating. Most but not all are still green in color.
Also as far as i am aware in the wood industry "marine" plywood goes by APA grading and is not pressure treated.
I'm not trying to argue with you guys just trying to make it easy for folks to find what they need. If you call a plywood distributor looking for "marine" plywood it will not be "pressure treated". If you go to Home Depot and buy "pressure treated" it will not be "Marine Grade"
And if you visit a real lumber yard that deals a lot in treated lumber used in saltwater, such as docks and boatlifts, etc. and then ask them for marine grade plywood, you are going to get CCA treated (the old stuff) plywood.
Not many consumers are going to be buying any type of plywood from a plywood distributor.
And thus the advent of CCA treated plywood also being called "marine grade plywood" is very likely.
As provided in post #11 there are companies that provide "Marine" grade that has been "pressure treated"
"Marine" is a grading term "Pressure treated" is an additional process added to a many grades of lumber and plywood.
I hope i am being helpful![]()
CCA treated is the old formula I refered to.
Here ya go, from the EPA...............http://www.epa.gov/oppad001/reregistration/cca/awpa_table.htm
Try CCA-C9 or CCA-C18 or CCA-C22
"Marine construction: Wood used for piling (sheet, round and square), Timbers, Walers, and Plywood and Framing, Stringers and Cross Bracing; wood for marine construction for salt water use (also includes brackish water) (immersion and/or subject to saltwater (or brackish water) splash ["subject to saltwater (or brackish water) splash" means any member of a marine structure which is positioned above mean high tide, but is subject to frequent wetting from wave action]), [Pilings (sheet, round and square), Timbers, and Plywood; Walers, Framing, Stringers and Cross Bracing (2"x8" and/or 3"x6" and larger dimensions and treated to a minimum of 0.60 pcf)"
My first post to this thread was to point out that CCA treated plywood is getting to be called "marine grade plywood" by lumber yards that sell marine grade (CCA) treated lumber.
So when asking for marine grade, the buyer must be specific in what he wants.
I always love plywood threads, they are almost as good as "which oil" threads![]()
Yup you are right marine plywood is untreated, it is just one of those unexplained miracles how it can take constant submersion for years and years without failing and it is just normal untreated plywood, amazing stuff.
