confused again
ArneA
Now that I have bolted on the lower unit with the new impeller, I am not sure which way that impeller goes on. Clockwise, or counter. Havent put the power head on yet. Thought I would check before going further. Also, the base gasket the power head mounts on,,,,,,,does it get any sealer or do I just fasten it down with no sealer.
Thank you
Arne
Rick.
Re: confused again
No idea what motor you have but all mine turn clockwise looking at the top of the flywheel. Best of luck. Rick.
1946Zephyr
Re: confused again
Confusion is our middle names here. :D:D
Turn that shaft clockwise and you'll be good. It all depends on what direction your flywheel turns, when you pull the starter rope.
