LightningBob
Thread starter- Joined
- Mar 14, 2021
- 26
I know, I know the infamous rotation question, but hear me out.
I pulled an engine out of a boat with cracked water jackets. Engine is strong other than the block being absolute junk now.
serial number of the once installed engine:
5170446 - attached will be a picture to help explain confusion. On valve cover there’s a sticker that says “rotation CCW”
Uhhh the engine is counter clockwise? I thought with all the research I’ve done, all engines are standard rotation which I guess would be counter clockwise and the direction would be changed in the outdrive.
Well the confusion gets worse, I called merc tech and gave them the serial to an engine I’m cleaning up and making a few changes to - 6811396 and they tell me this engine is clockwise there’s no tag on the engine saying which way it spins
It will be about a week before I can bump both starters to see which way each FLYWHEEL spins and get 100% back to you guys.
I asked Merc what I need to do as far as dropping in this “newer” engine in my boat and several things were recommended (other than obvious flywheel cover needing to be changed/brackets etc) that I need a pre-90 alpha 1 gen 1 outdrive.
Well the serial number on the gimbal to the drive I have installed is 5235726 (1979 Merc 1...???? Idk) the bolt pattern on that gimbal for the outdrive is the same on my current out drive and an alpha one gen one outdrive.
Does this really need to be changed out to an alpha one gen one or can I keep my old outdrive
Does this mean, if the engine is actually opposite of the old one, I can just change Props?
I would imagine, both engines rotate the same direction, but don’t know for sure yet, and other than some minor changes, this should really be a drop in and get on the water thing
question of all questions: was counter clockwise a designation that was changed because they started to look at engine rotation from the other side of the
