egclassic
Thread starter- Joined
- Dec 13, 2009
- 128
Pulled boat out of garage to go fill it up with gas before the July 4th weekend price increase, and noticed a small (quarter sized) puddle of gear lube on garage floor.
Found that the lube was coming from the "weep" hole on the starboard side of the outdrive, none from the port side though. I cleaned it up and it seems to have stopped leaking.
Outdrive is a '96 Alpha 1 Gen II.
I did change the water pump last year in August and had it out on the river many times after, but this was the first time I have seen any lube leaking. I have only had it out once this year, due to the weather. Today, I ran it on the muffs, shifted in and out of gear a few times just to see if I could get it to leak again. I let it drain (water) and looked for any gear oil, nothing. The lube monitor was a little past the full line, accidentally put too much in last fall when performing the winterization/maintenance.
So, am I looking at the beginning of a failing seal of some sort?
