Oldcraneguy
Thread starter- Joined
- Jan 30, 2013
- 27
Hello all, Im Don, and new to this forum as far as posting goes but have read quite a few posts of late and learned a bit just as a observer but alas it seems not quite enough. I have an older (1969) 9.8 With an intermittent spark problem, it has weak spark at idle setting (turning with a drill) then as soon as I advance the throttle the spark quits and doesnt return till I get past the "start" point. Its still weak at that point then gets hotter the further I advance the throttle.
Ive grounded my shut-off wire (orange) and checked my output wire (green) on the CDI showing 550-900V on the AC setting on my multimeter, and the coils show between .990-1.01 ohms from coil output wire to ground, the points and insolator blocks look brand new and have been regapped to .020. Im kinda at a loss as to why my spark varies so much with throttle movement and quits completely in the "shift" area. any help would be greatly appreciated....OCG
