I bought a 93 astro S-18B last year and am having problems figuring out how the livewell system works.
When I purchased the boat, both pumps in the picture did not work. I recently replaced the pump on the left and it runs now. although the pump runs, it doesn't seem to be pumping water into the livewell. The problem, and question I have is related to the valve that both pumps are connected to. They appear to be cable operated and from reading around about these valves i've come to find that there must be an actuator somewhere in the boat. I cannot find the actuator and I really can't understand how these livewells fill, drain, and recirculate. The way it looks to me is that both pumps are somewhat of an independent system in that depending on the placement of the valve the pump can either fill, pump out, or recirculate the livewells. If anyone understands these fancy livewell systems better than me any help would be greatly appreciated as my livewell is essentially useless right now.
here is a closer picture of the pump i just replaced. take my word for it that it is connected to that valve underneath the black hose covering the connection.
