connecting a voltage meter
Bob1944
I am remodeling a 15' Starcraft to fit my fishing needs and using a 1963 40 hp Evinrude electric shift for power. I want to install an amp guage and volt guage. I have a manual that shows how the amp meter is hooked up but not the volt meter. Any suggestions on how to connect the voltage guage?
bob
Silvertip
Honorary Supreme Mariner
Re: connecting a voltage meter
Forget the ammeter. The alternator on that engine does not have enough output to make an ammeter worth while since the needle would rarely move. Plus there is way too much heavy gauge wire involved to both with. A voltmeter is far more beneficial, easier to connect and provides a very distinct indication of whether or not the charging system is working. One wire goes to ground, the other connects to switched +12V (any wire that becomes active when the key is in the run position). If you have any other gauges on the boat, connect the wire to the +12 volt terminal on any other gauge. If the gauge has a light, the light wire connects to the light wire on any other gauge that has a light.
Bob1944
Ok, good advice, thanks
bb
