Ok OMC guru's.
On a crossflow con rod at the big end, do the sides (not the needle bearig surface) have any type of babbet material where it contacts the crank?
The reason I ask is because I began cleaning my parts for a rebuild and noticed what looked like galled aluminum on the sides of the big end on the rods. A couple of the rods were spotty and a couple had full coverage. I was able to remove this material using a razor blade. I was thinking this was aluminum from the pistons and had been galled onto the rods, but if it is actual bearing material applied at the factory, I will need new rods.
