Console rebuild.
B Mann
I have the deck complete and going to rebuild the console. Does it make a difference if I use pressure treated wood or regular plywood?? 1/2 or 3/4 inch???
B Mann
HotTommy
Pressure treated should resist insects longer, but the chemicals can react with metals and cause corrosion. If you're willing to spend more up front to have something that will last longer than plywood, consider something like synthetic marine board made of plastic.
ahicks
Yup. The heavy vinyl/plastic consoles that are available are not that expensive, work pretty good, and will last forever. Highly recommend that route vs. a home built.
I would probably laser one out of .090" aluminum and weld it up.
ahicks
Just do a search for "pontoon boat console" on Amazon
They have them in plastic OR alum.!
no, 5052 sheet so it would form easy and be naturally corrosion resistant (its what aluminum boats are made of). Diamond Plate is 6000 series, so its harder to bend and it is not marine.
B Mann
I need a friend like you around here!!!
