chambers1517
- Joined
- Aug 14, 2009
- 205
I have an 08 Caravelle Interceptor 232 with a 350 mag. When I run down the river I get a constant alarm when I hit 5000rpm. I thought it may be the drive fluid level since I was trimming up at this speed. That is not it. I thought maybe the rev limiter but I have to slow all the way down to idle to remove the alarm. I loose power when the alarm is sounding. All gauges are in the normal range. Would an over rev alarm do this and require a back to idle to reset? I had the alarm start at 4000rpm once over the weekend. I also ran for 5 minutes at 4950rpm with no issue and went to 5000rpm and immediately got the alarm. Any ideas? The alarm is a constant high pitch.
