bob johnson
- Joined
- Feb 25, 2009
- 4,306
Got my 1995 johnson Ocean Runner 115 hp rigged onto my boat this weekend.
I had a 1997 evinrude Ocean Pro 90 HP just before this, so all my guages are the same...both used the system check tach.
with the 115 after running a few minutes the alarm( continuous) goes off and the HOT light comes on....after about 10 seconds or so, it goes off on its own. But the red light stays on that says HOT.
I have a temp guage with a switch for two senders, but this motor only has one sender( other than the two factory SENSORS)
the guage never went over 160!!!
the water is pumping hard...I have a pressure guage and the pressure never goes below 10 psi and goes all the way pasy 40 psi under way.
The tell tale is always strong.
I pulled the cover, and put my hand on both heads , they both felt the same....so i get the idea the head with no temp sender is the same temperature as the one with.
then I dont get the alram any more, but the red light stays on.
until i shut it off...
and then after a few minutes, the alarm goes off again....then goes off after its 10-15 seonds.
If I could find a Temp sender( very hard to do for this motor) id install it on the other head.
The guy warrantied the motor, so i dont want to pull thermostats and just replace for peace of mind..
the VRO is not used and there are a few wires un connected...a tan and a black and a plug with 4 wires
is it safe to continue running?
i never got the red light staying on on the 90 hp!!! and never got an alarm at all
thanks
bob
thanks
bob
