Constant drain of 1 of 2 batteries
nola mike
So no connection between the batteries? What's a parallel switch? And stbd is the draining battery? Seems like an odd setup.
dingbat
One of the batteries for stbd engine and everything else, the other battery seems to be for port engine only. and I have a parallel switch on dash.
A battery switch on the helm is weird.
Never heard of or seen of such a thing on a Grady.
I have a light at the helm that lets me know when the ACR is active.
Have a OFF/ON/Combine switch on the transom
What year and Model?
All the Grady wiring diagrams are on-line
crazy charlie
Got the boat with that setup over 20 years ago and never thought twice about it. Never an issue. Parrelel switch is a spring loaded toggle on the dash which when held to "on"connects both batteries momentarily for startup when 1 battery is weak.
dingbat
Can't be a regular battery switch, it would take too much high current wiring
Not necessarily.
A 12V switch would be all that is required to actuate a remote battery isolation relay.
If that is the case, that would be high on my list of things to check as well.
nola mike
Not necessarily.
Yeah that's why I said "regular", would have to be a relay trigger with the relay near the batteries, which is what it sounds like. A stuck closed relay might do strange things
crazy charlie
The switch is working fine and does exactly what it is supposed to by giving me both batteries for the moment of cranking to start.
crazy charlie
Draining stopped a few days ago. I have done absolutely nothing to troubleshoot yet, I have not even run the motors. Makes no.sense ....
crazy charlie
Still not draining, Can't understands that but let me leave well enough alone for right now.......I guess
Captain of the Double G's
It is a 1988 ? You should probably rewire everything no matter what.
Nice thing is you could customize all the circuitry to your specs. Yes I know its not the answer you wanted.
Haven't been here long but appear to have an exact answer for everything.
