jdlloyd_iboat
Thread starter- Joined
- Jan 15, 2006
- 52
1990 V-6 XP-150 Evinrude -- Motor and boat sank 2 weeks ago but I was able to raise it and get it running for an hour or so the next weekend. I had to dump the oil reservoir and refilled with new oil and its full. I am running a heavy mix until I know VRO is operating and mixing oil. Electircal problems showed up this week. My warning horn now runs constantly even with engine off and cold (key on). The boat sank such that the throttle controls (where horn is located) never got submerged. My dash and gauges also did not submerge.
I checked temp sensor wiring and have not found anything obviously grounded yet. My trim meter also stopped working (worked Ok first week). I read the forum on this problem with horn and heard that the VRO reservoir level wiring might cause problems. I checked the oil level sensor wiring (2 black wires to sense oil levelin reservoit) one is to ground and the other was already disconnected! (I have had boat 2 years so this just came to my attention). Not sure where this free end should connect anyway. I checked the larger tan wire (16 gauge to low oil switch) and not sure where it is supposed to go either so not sure if it is part of problem or not. Does this somehow read oil pressure at the VRO pump? Coincidentally I also notice my purple wire to the harness connector had been cut by some previous owner (this wire goes to rectifier/regulator and seems to be not part of this problem but might explain why rectifier does not charge battery. I have a SELOC book but does not seem helpful for these problems.
Summary, Horn sounds constantly with engine cold and key on and when engine running. Seems not temperature related. Any ideas? And although not as critical, what should i do with the purple wire in the harness that is severed? Tilt/trim gauge, sensor or receiver problem? How could I check?
Thanks,
Jim
Thanks,
Jim
