Kranjack20
Thread starter- Joined
- May 7, 2023
- 105
So I now have another problem with my motor. It’s a 1998 Mercury tracker 40hp 2 stroke oil injected. I had it running on the muffs and it runs good. But randomly after a few minutes of running on the muffs a high pitch persistent ringing started coming from the throttle on the console. The ringing doesn’t change it’s just a constant ring like when you first turn the key on for your motor and then the ringing stops once it starts. I turned it off and then turned the key once without starting it and it made that ringing noise without the motor running. Btw before it made no ringing noise at all even with the key just turned before you start it. I can’t find any information about this online. The motor runs good, pees water good, has over a half tank of oil since its oil injected. The motor wasn’t overheating because it wasn’t running long. I could hold my hand against the cylinder head. There was fuses under the steering console and I pulled all of them out one by one with the ringing noise going but none of the pulled fuses stopped the noise. So I’m kinda lost right now. I just made a previous thread for a different issue and as some of you may know the alarm wasn’t going off in that video…included pictures of the fuses.
