Constant 'Two Beeps' from my Four Winns 4.3
Jimwhall
Took my '16 Four Winns with a 4.3 MPI and alpha one out to watch fireworks. I did alot of idling and slow moving and when I went to land it I started getting two warning beeps every minute or so. Time between beeps can be variable.
I pulled it and checked:
A) oil
B) drive lube level
C) confirmed oil pressure
D) confirmed normal temperature.
E) confirmed voltage.
Everything works normally. I ran it again and it idles and planes just fine. It ran rough at the beginning of the season but seems to have evened out with a tank of fresh gas. I'm confused, and as it's a 'new to me' boat I don't have any manuals. My boat mechanic has a four week (!!!) back log. The online manuals seem a generation older than what I have. Can anyone provide guidance?
Ayuh,..... Bein' an electronic motor, you need a 'puter to know what it's tryin' to tell you,....
BillWilliams
You actually have 3 serial numbers. One for the outdrive, one for the transom assembly and one for the engine. Depends on the year but some boats (like my 1999) has all 3 on the cover over the engine. My 1989 boat had the engine serial number on a sticker on the valve cover. You'll have to take a look and see what you can find.
Jimwhall
What's your serial number?
I don't know. Is it just on the block?
A) oil
B) drive lube level
well…. I drove it around and it seems fine. After that my mechanic called and said not to run it though. I guess I was going on the theory that if I have oil, oil pressure, temp is good, volts are good, and it’s running fine I would t damage anything. I wanted to test it though. Hopefully I didn’t make anything worse.
I did find a sheet explaining the horns. It could be one of like 14 things. 🤣🤣🤣
Stinnett21
FWIW My 2002 5.0 MPI used to do this on occasion. I upgraded my battery to 1000 MCA instead those rated below 800. I learned to keep the IAC muffler clean, the flame arrestor clean and the hose leading to it and problem went away and hasn't reoccurred for several years now.
Jimwhall
A) oil
B) drive lube level
I think this is the power steering pump. Can anyone confirm? Or tell me if it’s low?
Serial shows 555 ECM
The highest failure rate item on your motor is the sea water pressure switch. I'm not saying that's the problem it's just they fail often
The pump above is the Trim pump, it raises and lowers the drive.
The power steering pump is belt drive and on the front of the motor. The link below shows your PS components
https://www.mercruiserparts.com/bam/subassembly/31503/13808/260
Jimwhall
Jimwhall
So… what does that switch do? And did the reservoir for the trim look low? I can’t see any marks on the jug.
I called it a switch but its actually a sensor, and it tells the ECM if water pressure after the raw water pump is low. Located above and at the rear of the motor on the power steering cooler, item 14 in link post previous
Yes it does look a little low. It should not be full but right at or below the bottom of the ridge of the tank top
Jimwhall
Thank you again.
Can I use just regular power steering fluid for it? Looks like Mercury Marine fluid does both
Jimwhall
Just an update for all who helped, turned out that both the impeller and the water pressure sensor had gone bad. According to the mechanic engine is still fine, which kind of makes sense to me because it never got hot, or even a bit warm. Nice to have behind me though.
