mark in new jersey
Thread starter- Joined
- Sep 7, 2011
- 167
The restoration is moving forward. My machining issues on the shaft have been resolved, so it's time to rebuild the lower.
I really don't have the means to do a meaningful pressure test; I have no means of doing a vacuum test at all......so I was contemplating this:
Complete rebuild, seals, sealant, everything, but no oil and not reconnected to the exhaust tube.....then once everything's dry & closed up, I'll simply submerse the entire lower into a deep garbage can full of water. By doing so, it will be immersed deeper than it will ever be when on a boat, so the hydrostatic pressure will be more than it will ever see in actual service.
I'll leave it there a day or 2, then open the lower fill screw. If it's dry, then everything's good. If water comes out, then I have an issue & will need to seek a pro who can determine the leak's location.
Is that a plan, or just a dumb idea? It seems ok to my engineering mind, but you guys know way, way, way more about engines than I ever will!
Thoughts?
Thoughts?
