LilRedNeckGirl
Thread starter- Joined
- Jan 25, 2010
- 184
Ok, 1978 johnson 70 EL, with the Johnson Command center. First command center wouldn't go into reverse, so a used unit installed, worked fine a few days, then
"~~ SHABAM~~"
the same problem.
Im tired of buying used junk, sick of single levers that are prone to fail, gears and cams that wear out, and days intended for fishing spent stranded at the dock.
Can anyone point me to a dual lever, NEW unit that has a key start and is compatible with my engine?
All im finding are these huge top or recessed mounts. I need a side mount, right side, for a 15 ft Glastron.
