control cable replacement for bayliner capri
tigu3re
Hey everyone does anyone know what can of control cable ill need for a 1990 bayliner capri U.S marine l-drive 120ld90c
ajarvis
Re: control cable replacement for bayliner capri
I just replaced all the cables on my boat, shift and throttle, 8 in all. Look at the ends to see what type you have. I had to pull mine then measure them to get the right ones. When you pull an old cable out be sure to pull a cord or small rope thru so you have something to pull the new one back. Good luck!
jerryjerry05
All control cables will have the model# and length stamped in the plastic sheath on one end.Most Bayliners used Morse red cables.Others will fit.Make sure they are the same length.Too long and they won't work as well.J
tigu3re
thz very much everyone i got it workin great thz hopeful ill be in tha water by june
