TOY BOAT
- Joined
- Aug 11, 2011
- 50
I tried a search. I really did, but came up empty.
So I purchased a 1985 75 hp mercury outboard with tilt and trim. It came off a pontoon boat. The controls are quicksilver console mounted with tilt and trim button, and cables exiting from the bottom. The cables are about 17' long. Problem is that the boat I have is a 15' runabout that needs side controls with tilt and trim. Also the wire harness connector is internal on the motor, and not external like the 79 80hp merc I had before. So my question is. Does the wire harness from the motor to the control typically come with the motor or the control? Should I save my wire harness? What control do I need? Is there a part number I should be looking for if I am looking used or new quicksilver. And finally, what length cables do I need?
Thank you
Thank you
