drewpster
- Joined
- Oct 17, 2006
- 2,059
I have to replace the transom on my tri-hull.
I plan to remove the cap and possibly the inner skin of the transom to access to old core. I plan to replace the old wood with new marine ply and replace the inner skin. I may either totally reglass the inner skin or glass the old skin back in depending on how much damage I do removing the old core. I am not a big fan of the chainsaw technique due to bonding issues.
I have two concerns. One; I plan to do the work with the hull on the trailer. The trailer supports the boat via two bunks that run along the bottom of the boat and extend past the transom about 6 inches. Should I add support to the hull sides or anywhere else to prevent warping?
Two; It is likely that I will have to build the new transom out of two pieces of 3/4 ply to make the proper thickness. (cut from a template then bonded together) When I glue the two pieces how can I better insure that the new wood will not warp due to resin shrinkage? I was planning to bond the two pieces with mat and poly. Should I consider epoxy? All the rest of the work will be done with poly because I am as broke as my boats.
