Controls from a 115 to a 150 Will they fit ???
grady84
I have a chance to pick up a pair of 150 Evinrudes. I currently have a 115 on an 84 Grady Tournament. I would like to put a single 150 and keep the other for a spare !! Will the controls fit both motors? The 115 is an 84 and the 150's are mid 80's also. I'm going to look at them over the weekend. I'd like to hear that it would just "plug in" !! Thanks
freddyray21
Re: Controls from a 115 to a 150 Will they fit ???
I would imagine they would, but if you have a manual for both motors the wiring diagrams should tell you.
Walker
Should hook right up.
tashasdaddy
disconnect the wiring harness plug on the 115, then compare the plug in the 150. they should be alike.
Dhadley
They'll both have the red cannon plugs on the harness. A direct swap. Even the throttle and shift. No problem.
Dhadley
Lol!! Had to edit the last post....it's amazing what happens when you leave the " f " out of "shift".
grady84
Sorry for the late reply... Thanks !!! I did check them Sunday ( said I was out XMas shopping but went and checked on the boat). Took pics and yes... The red plugs are the same.
