Re: controls question
Once you get the shift and throttle plate in, put the cup and bearing in and slide the spring in behind it. I take a screwdriver and put it close to the end of the spring in one of the spring windings and that helps compress the spring into the slot. Other times I've used a screw driver like a shoe horn to help slide the spring in. Once the spring is in, put the cover on. These springs will disappear from the face of the earth if they pop out.
