1966starcraft18ft
Thread starter- Joined
- Jul 22, 2012
- 90
hey guys!!!!! long time since I've posted. I have a 1998 MonArch SunSpa 260 pontoon with a 1988 Force 125 hp outboard. Model number 1254x8A. we have only had this pontoon 2 summers. Does anybody have a part number for control cables for this motor? The cables that are on my motor currently are Teleflex CC17222. I've had stiff shifting issues into forwardand reverse and then this last summer, i had intermittent shifting into reverse issues. Only into reverse. would grind a bit then go in. I can disconnect the cable at motor and manually operate the shift lever under the motor hood and i have to move it all the way forward before it will go into reverse. if cable is hooked up, the arm is roughly 1/2" shy of going into reverse.
I am trying to figure out if my problem is the cables or issue in lower unit.
any help would be appreciated.
also, if the lower unit is boogered up and i gotta swap it out, does anybody know if there is a 2:1 gear ratio lower unit? i am led to believe there is but im verifying.
are there other lower units that i could use to maybe use the bigger props from a mercury so i can maybe prop this motor down so i can get it into its recommended power band?
