This also reply posted on previous 1974 115 conversion to 135 hp'
Unread Today, 10:20 PM
jaf65 jaf65 is online now
Default Re: 1974 Johnson 115HP conversion to 135HP
This is a request for DHADLEY and/or IWOMBAT for a candid reply post to the following. Don't hold back -I respect your expertise!
In looking for a 90-140 hp motor for a 24ft. Pontoon I ran across (have not seen or heard it yet) that is reported to be a 1977 110hp Johnson (I think really a 115hp and a 1978 yr). The story is the owner (he taught shop tech) had his class under his super. take this motor and do a conversion by boring cyls. to .064 over, new Sierra Pistons, rings, bearings, seals and gaskets. rebuilt carbs off of a V6 Johnson with 1.75 bore. "Bell" Exhaust and one new coil. No mention as to new or replacement heads. This man died before it was even run and his friend got it from wife and then sold it to the man who is now trying to sell it. This conversion was 6 yrs. ago and it has been upright on a rack inside since. Was started by seller in 1999 foe 2 minutes and reportedly ran strong and peed water. Reportedly T/T had worked when purchased by seller but now does not operate but makes a sound. Pics show a bubble looking back and a metal front where the 4 carb . throats are visible (no cover over front). The carb throats are two on top and two lower each set of two horizontal to each other. Neither seller nor myself are particularly adept at this level of marine mechanics. So, the questions dor yhour comment are:
1. Does this sound like a proper conversion
2. If purchased would you expect additional work/parts needed?
3. for general use on pontoon boat is this a good motor?
4. If I go to inspect motor for possible purchase, what tests/visible condition should I look for?
5. Should there be some sort of cover in front of the metal part where the carb throats appear.
6. should there be one or more power packs on motor or can electrical be converted so as to not use coils
7. Would you recommend this to a basically non-mechanic?
8. Does the resale or part-out value of motor worth the sale price of
$700.00
9. If better to discuss over phone reply here and I will give my number.
Sorry this is so long but am at a confused decision point
$700.00
