rolmops
Thread starter- Joined
- Feb 24, 2002
- 5,751
So I completely finished my 221 Islander project. It works like a dream . This 1989 rig with a new 4.3 engine and cobra outdrive in great condition is very nice indeed. The only problem is that it is all done. I like to putter, build and change things. So now I am thinking about changing it to an outboard driven setup. This will enable me to fish until the water freezes over without having to worry about winterizing.
I am toying with hanging a 150 or 200 horse engine on it.
Now there is the bracket possibility which to me is not so attractive. There also is the seadrive idea. Which seems a bit more attractive to me, but the they are very hard to find and most comments about them begin or end with negative opinions.
I am thinking of using a hydraulic jackplate with an extension piece to go between the jack plate and the transom. The extension piece would bring the outboard to about 12 inches behind the transom so the engine can be tilted. The outboard itself would be a 25 or 30 inch shaft so it can sit high up on the transom while with the help of the jackplate I would be able to bring it even higher up or down.
It would be more like a sea drive than a bracket because it was be closer to the the transom. But It would not be the monstrous weight of a seadrive.
Do you have any opinions about this? Is it doable or is this just another impractical idea
