haulnazz15
- Joined
- Mar 9, 2009
- 3,720
Does anyone have any experience with swapping the log style aft exit exhaust manifolds to a center-exit manifold? My manifolds/risers are who knows how old (over 15 years for sure, quite likely original equipment (33 years). In any case, I believe that the failure of the riser or manifold is what has caused the water in my 351W. I have secured the purchase of a 90's 351W long block to swap in, but I don't want to reuse the manifolds that likely caused the problem in the first place.
I have seen many of the center-riser manifolds that look like they were used in the inboards, possible some of the inboard/outboard applications. Is it possible to convert to the center-riser and still use the y-pipe design instead of making it a thru-hull? It seems like you'd only need to buy the risers and manifolds then find a length of rubber exhaust tube to connect the riser/y-tube.
