Woodonglass
- Joined
- Dec 29, 2009
- 25,933
Re: Convert 14' runabout into fishing boat for the SW FL flats
There is nothing wrong with any of your statements. Fabric is all that's required when using epoxy when tabbing wood to the hull. No CSM needed. Since epoxy takes longer to cure it's a bit more difficult to work with on vertical applications and requires a bit more "BabySitting" and as stated more pricey but it does create a stronger bond and more water resistant. It should be noted that Your boat is made entirely from Poly and your methods of application and care will far exceed those of the MFG and would be more than satisfactory for the rebuild but if you have experience with epoxy and feel comfortable using it, then by all means use it. You're costs will only be maybe a few hundred dollars more if that. That's my 2?
