convert 3 wire tilt to 2 wire??
JesseNKim
I started a new thread because i see alot of people asking this but no true answers so here goes nothing...
Ok i have a 1971 johnson 100 v4 it has omc tilt from factory on it now it has a 3 wire system Black/blue/and green i saw on ebay a 3 to 2 wire conversion with relays would that work my system because i cant figurw out how in the world it hooks up like this i put black on ground on battery and when i touch green to pos it goes down but blue wire does nothing any which way i.put it do i need a solenoid or possibly a relay??
Re: convert 3 wire tilt to 2 wire??
Positive battery terminal to blue should make motor trim up. Positive to green should make motor trim down. You might open up the motor and see if you can determine why motor does't run. Maybe the wire broke and you can repair it.
Is there a replacement motor for your PTT that has only 2 wires? If so, you will need to set it up with two relays to replace the solenoids.
