I was going to look into converting an old I/O with spent motor to an outboard via a mounting bracket. Is this something I could do or is this something that requires pixie dust, which i'm fresh out of. Ive looked into brackets and they say bolt on and go, but surely there is a weight difference in an outboard and an I/O that must be compensated for. It seems to me that the I/O would be much heavier causing it to be front heavy once converted. Also how would the mounting height be determined as if mounted too low your motor could get a saltwater bath and too high the prop would come out of the water?WOW
