convert reverse rotation to regular rotation?
stackz
1986 175hp 2-stroke yami engine.
its my neighbors. we've pretty much done everything to this engine thats honestly possible.
now, he's down to just having problems with the foot. the big outer ring nut thread portion is pretty much eaten to nothing and it no longer grips right so he keeps getting water in the oil in the foot (and it has hairline cracks he refuses to acknowledge...). also, its making a whining noise even after being reshimmed/setup.
he's realizing he just needs a newer foot.
I'm thinking he should just convert to regular rotation as I'm pretty sure its just the gears in the foot being reversed are what does the functional part. if he buys a rebuilt regular rotation foot he should be good right?
swap that on and bam, regular rotation?
stackz
Re: convert reverse rotation to regular rotation?
nobody?
pine island fred
Should make no difference at all. Of course he cant use his current prop. FRED
Rich Hargis
You will find that a right hand rotation lower unit will work fine. You will need a right handed prop as stated above as well.
mikesea
counter rotation lower units ,as well as the parts are hard to find used.I suggest he look to sell his old parts,that may help defray the cost of another standard rotation lower unit.Be sure when searching for the standard (that will work as mentioned ,with a standard prop)he gets the proper shaft size,they come different lengths
99yam40
I am not sure about the Yamaha but on a Suzuki there was linkage that was different that needed to be changed also
