Converting 25hp Johnson from tiller to cable
Suwannee1
I'm a new poster, so please forgive whatever ignorance I display. I've done a little searching and can't find the answer so I'll post the question here: Is it possible to convert a 1973 25hp Johnson from tiller control to cable control? I want to do that so that I can set up a stick-steering system to control the boat from the front. Immediate questions are: a) does the tiller need to be removed? b) does the bottom portion of the cowling need to be replaced with something that will allow cable access?, and c) any suggestions on a particular conversion kit? Thanks in advance for any responses, dlg
tashasdaddy
Re: Converting 25hp Johnson from tiller to cable
you will need this conversion kit, the tiller can stay on if you like, i always leave mine.
you will need a throttle shift and control box. http://cgi.ebay.com/ebaymotors/ws/e...0339542147&sspagename=STRK:MEWAX:IT&viewitem=
i assume this is manual start.
you will need the stick steering kit, and transom conversion kit.
here is my conversion of a 1955 15hp with stick steering.
Suwannee1
Thanks! That's what I was wondering about. I bought the old boat, motor, and trailer for $300. Motor runs like a sewing machine. Problem is, I can't get my wife to go out in the boat much anymore, hence the problem with the bow riding up. Looking at the photos of your boat and conversion explained alot of questions I had. Thanks again for the info. dlg
benjoefoe
I am doing the same thing w/ the same motor!! Is there any linkage that needs to be added to the shift or throttle on the engine for the cables to attach??
thanks!
benjoefoe
Thanks, and about the steering.... what size linkage do I need that goes from the motor to the rod that goes thru the transom? Is the linkage something that is universal or do you need a certain size for different motors?
thanks
