Technorunner
Thread starter- Joined
- Oct 1, 2010
- 95
HI all
i have searched and googled myself blue with this.
A little background: my friend bought a funlinear 195 fantastic with a mercruiser 130 and a alpha one gen1 1998 y/m
he had had it in water only 2 seasons second season he found water in the oil.
he took the engine out and took it a part , the cyl.head gasket was in bad shape so he hoped he found the problem. But to be sure he pressure tested the cyl.head and the exhaustmanifold. and they found no leakage.
so he changed all bearings and rings and so on when he had it a part.
he put it together and started it no water in the oil.
he took it down into the water and after like 5 min there where water in the oil again. so he took it up and let it be for like 4 years then i ?bought it cheep from him.
with the 130 hp engine it took forever to get it up in plane
so either the prop is way to big or the drive has the wrong gear ratio. and there is no label on the sterndrive left to tell what ratio.
so i bought a 95 astro vortec engine complete with engine cable to ecm and the ecm with it. Its a CPI engine and have 195 KW in the car.
so i have bought a manuell 168teeth flywhell.
i have had the ECM reprogramed in swedens best tunning company.
and they removed the O2 sensors and fault codes related, EGR and faultcodes. reprogramed to manuell so it skips transmissionsignals and removed VSS signal.
he also made som small adjustment to timing and fuel.
But if i want to run it in closed loop he toold me to take a preheated O2 sensor and make a thredded adapter to fit the EGR valvehole and put a O2 sensor in there and make a pipe from the O2 sensor bung to the cow horn.
It only needs to be like 8mm in diam to have a little flow. because your always (almost at least) in same throttellevel. And in the ECM GM had made 1 nice mode called highwaymode. If you have the same throttelpossition for a little longer time it uses the O2 sensor to leanout the engine. And thats the only reason im thinking of maybe program back the O2 sensors.
i have a friend making the wet manifolds in stainlesssteel for me
but in most it will remain a car engine since i got pretty much Hp over.
but it has the same WOT rpm as the 130.
So this will be a CPI boat engine. with alot less vapours from the gas in the engine compartment a little better fuel consumption
and better coldstarts.
please feel free too leave a comment.
And i know my English isent the best
And my background with engines is 12 years as a truck engine mechanic in R&D at Scania here in sweden
