Converting a Simplex control
jusfloatin
Good day to all
I have been seaching for a vintaged engine control to run twin motors with zero luck.
This has brought me to the point where I am considering just stacking a set side by side but without trying I know I would have to bend the handels to allow them to operate properly. Or I would have to space them and that would look hookie.
Before I rush out and find a second one does anyone know if I could make one unit run just the shifters and the other just run the fuel?
This is the unit I have.
F_R
Honorary Supreme Mariner
Re: Converting a Simplex control
Nope, can't do that. One lever pushes the throttle cable and the other pulls the shift cable (when you move the levers forward). So your plan would result in one throttle and one shift working backwards.
Moreover if you should consider merely stacking two controls as is, your handles would be throttle-shift, throttle-shift (not throttle side by side and shifts side by side)
jusfloatin
I feel stupid not to realize it is just that simply,
"So close but yet so far far away"
ezeke
Click the thumbnails for something simple.
That's part number 0173287. Marineengine.com says they have two in stock.
jusfloatin
That would be exsactly what I would want but it would look a wee bit out of place on my 1959 Thunderhawk.
captk
A 4 lever control was offered back in the late fifties that matched your simplex Part #277876. I remember seeing some boats with twin 35s back then, keep trying ebay or really old dealers. good luck Bill
F_R
Just a "wee" bit. Actually, the rectangular control came out in 1961. Only a couple of years off
