Redbarron%%
Thread starter- Joined
- Dec 7, 2017
- 479
OK I confess I have created a *astard ignition motor going from a CDI with switchboxes to late mercury CDM modules for (maybe ) improved reliability.
I have a couple of issues, however and maybe someone can help me out.
First the CDM modules are readily available on Ebay as is the three cylinder harness to mount them to the motor.
The issue is with the bias circuit and the trigger coils.
As I now understand it the old CDI had the bias circuit built in the switch box where the new CDM has it buitl in the trigger coil. What is the bias, you ask? Again as I understand it the bias circuit is a negative voltage added to the trigger voltage to bias the point where the trigger fires the SCR in the pack down as the voltage rises due to increased rpm from the trigger magnet pickup. The arrangement of the magnets in the flywheel and the coils in the trigger is different between the CDI and CDM ignitions, however the pulse from either will fire the CDMs, but the timing may be wrong with the mixed parts.
Since with my setup there is no bias voltage generated in the trigger coil circuits the timing may be advancing too far or triggering incorrectly with the unbiased output from the coil.
Does anyone know what is in the new trigger that creates the bias in the CDM units?
I suspect that the voltage generated by the trigger coils could be rectified in a bridge and somehow subtracted from the voltage applied to the CDM.
Again as I understand it a 0.60 positive voltage at the trigger input to the CDM will fire the SCR and a voltage of ~25 volts negative is applied at higher RPMs ti keep the faster rising voltage as the RPM increases from triggering the SCR sooner and advancing the timing too much.
I have a miss at high RPM that may be related to the lack of the bias circuit in the FrankenForce ignition system I have created.
I hate to get a late flywheel and trigger to test the theory and also to go back to the old CDI system.
Anyone have any ideas or knowledge about just what circuits are in the new CDM trigger?
I had assumed that too much voltage out from the CDI triggers would not be a problem as long as it would fire the SCR, but at the time I was unaware of the bias issue.
Sorry for the long technical post, but what to do?
Thanks,
JD
PS.
The new style CDM triggers cannot be tested with an ohm meter test and I think that the additional circuitry is why.
I have seen a circuit that has a resistor network from the pick up coil (3) and a voltage divider network to back to back 5.1 volt zener diodes to limit the voltage to 5.1 volts plus and minus and this may be all that as needed as there is not room in the trigger for a lot of electronics. I may try making this circuit on a perfboard to install between the trigger and the ignition harness.
s.
Thanks,
JD
PS.
s.
