bonz_d
Thread starter- Joined
- Apr 22, 2008
- 5,276
Hello folks,
Here is the situation, I have an opportunity to puchase a very nice newer (late 80s) 28hp Johnson long shaft with low hrs that I would like to put on a short shaft boat. The reason being is the boat has a rack steer console and I don't want to monkee around with rigging up something to be able to use the old 18hp Evinrude I have. The cost of some of the prefabed kits I've seen is almost half the cost of this newer motor. Besides the 28 is electric start also.
The question is, The 28hp has the older style split gearcase with the extension and not the newer one pc. thru the hub exhaust gearcase. So what yrs or models short shaft gearcases or drive shafts fit or interchange?
I wouldn't normally consider this but this size range short shafts are very hard to find around here and the ones I've seen are fetching premium prices and most of the 25hp models are set up for tillers and do not have the steering tube.
Thanks again,
Kevin
Thanks again,
Kevin
