seattle scott
- Joined
- Nov 1, 2011
- 113
In 2010 Frank Acampora posted: It is really quite simple if you already have a points distributor.
Since the engine is a 12 volt engine with no bypass circuit during start, you need a 12 volt coil or a 9 volt coil and ballast resistor. Run blue wire from "I" terminal of the ignition switch to the POS side of the coil. Run NEG side of the coil to the points. That's it!
Note that the spark will be a bit weaker than the CD ignition and surface gap plugs may not fire.
Do not leave ignition on while engine is not running--coil will be energised and eventually drain the battery
CD stands for Capacitor Discharge. Inside the CD box are large capaitors. the points or the electric eye shutter signals a transistor to "Dump" the capacitors into the coil. The advantage is a very quick build of magnetic field and a sudden collapse, resulting in a much hotter spark than the dwell on normal points can deliver.[/I][/I][/FONT].
I have seen others posting the same information. So I have a 1977 85 hp Chrysler with a points distributor and a failed Motorola cd box. I bought a 12 volt car canister coil that did not require an external resistor. i wired the blue ignition wire to the Pos on the coil and ran a wire from the neg coil post to the points terminal on the distributor and installed the original coil wire in the coil. With key on I get 12.4 volts at the + post on the coil - didn't check the voltage with the starter cranking. I swapped out the surface gap plugs for the regular kind and put a condenser on the distributor post, where the wire form the neg post on the coil is connected. I did not mount/ground the condenser. Anyway with the spark plugs out and grounded I get no spark. Have I wired this up correctly? If I put the voltmeter probes on the coil terminals and crank the engine should I see 12 volts when the points close? I haven't done anything about the points, it looks clean but I haven't checked the gap.
Again, thanks to Frank for helping me get my 135 hp running.
