bplayer405
Thread starter- Joined
- May 3, 2013
- 29
I have a '57 Johnson 18 HP Seahorse outboard that I was going to sell before doing a little research. I wanted to have a motor to use as a backup for my 48 HP Mariner to fish HP restricted areas. I just didn't want to run two seperate fuel systems from to front of my 16' decked Jon to the back. The Mariner is a single line system. My research showed an epoxy or rubber plug to stop the pulse flow in one side of the two ports in the reed plate where the check valves supply pressure for the two line tank. So I started taking apart my outboard. I removed the carburetor and linkage, removed the intake manifold, and removed the reed plate. On the reed plate I removed the check valve assembly below the reeds, required to have a pulse signal to a fuel pump, and checked the passage ways through this area. Brainstorm! Plate is aluminum. Epoxy or a rubber plug in this area could fail from fuel coming in contact. Why not use aluminum? I found a aluminum bolt left over from my transom overhaul and it fit the port in the reed plate perfectly. I cut it off short enough to use a hammer and swell the port shut like using a rivet. Then I filed the excess below gasket thickness. Now the port is sealed leaving one port open for a pulse signal for an aftermarket fuel pump using the existing fitting on the manifold and it cost only my time to tear the intake down. I feel using an aluminum bolt or rivet is a more solid and permanent solution to this modification and it still can easily be reversed if the need arises.
