Jimmy Starcraft
Thread starter- Joined
- Jul 8, 2024
- 48
Hi Everyone,
Was sidelined for a while but am back on on my 1973 Starcraft project and need advice on my trailer. The trailer it came on is a roller but in really rough shape. I have a load rite roller trailer from a previous boat that I want to switch it to.
The cross members on my load rite trailer are about 6 feet apart. Everything I've read says this span is just to far for a 2x6 or even a 2x8 on its flat side up. My boat weighs about 650 and the 70 hp about 260 so Im thinking with gear and other stuff about 1200lbs.
The plan I have that I am looking for advice on in this. If I remove the roller arms I will be left with the support bars and old brackets. In the picture the bracket on the top side of the support bars where the roller arm was attached I want to add a bunk trailer angle bracket on both ends of the old roller support bar. I would also drill another hole through the larger support bracket on the cross member holding the the old roller support arm to make it fixed. Then mount a 2x6 on its flat edge between the two. It would have a short enough span between supports and I think be a great option for me.
I hope Ive explained my idea so it makes sense. Am I out to lunch on this? is it just a dumb idea or does it make sense and would make this a good trailer for me.
I only use deep water launches so not worried about that. Want the bunks for better support of my old aluminum boat and long term storage plus cheaper than replacing all the rollers.
Thanks in advance for any advice.
