Bought a boat - don't know much, but learning. Taking it out on the 16th for the first time where I can use the 40 HP Mercury Force (1995). I heard that motor has had some problems????
Question: Read here that this particular motor only "spits" some water rather than a stream out of the motor. Is this true? How can I tell if I'm getting adequate cooling? Is there a built in safeguard if the motor starts to overheat?
I have a Johnson 9.9 as a kicker/troller which spews forth a remarkable stream of water - is the 40 HP Force supposed to do the same or not? It only spit a little when running with ears.
Thanks for all help and other insight on this motor I should know.
