I have a 1984 Johnson 35 HP
I can run a high speeds and no problem
If I go to trolling speeds the constant alarm goes off
I replaced the thermostat but to no avail
It will run on the water hose with no alarm
It does not seem to be overheating...but I am no expert
If I take off the alarm will not stop, but if I let it set for a while
I can take off with no alarm as long as I am planed out.
the water stream is working at all times.....
is this a water pump problem or temp sensor?
There is water getting into my lower unit..I replace the oil frequently
help!!
help!!
