Cooling sys. flush feasibilty question GM IL6
itstim
Older inline 6 GM 160hp seawater cooled:<br /><br />Suspect my block has rust build up in its cooling passages. Since angioplasty is out of the question I was wondering if it is feasible to flush it by removing t'stat, running intake water from impeller overboard, plugging overboard hose from manifold into water intake at t'stat housing, filling system with some "stuff" (Iron-out, CLR, radiator flush..?) and water and running eng. just long enough to circulate "stuff" and water and letting it sit for X # of hours and then re-hooking everything up correctly and flushing it out. Is this effective? What kind of "Stuff" would be best?<br /><br />Thanks
RatFish
Re: Cooling sys. flush feasibilty question GM IL6
MST sells some stuff that MAY be worth a try. Check iboats first.
Scaaty
Originally posted by itstim:<br /> Older inline 6 GM 160hp seawater cooled:<br /><br />feasible to flush it by removing t'stat, running intake water from impeller overboard, plugging overboard hose from manifold into water intake at t'stat housing, filling system with some "stuff" (Iron-out, CLR, radiator flush..?) and water and running eng. just long enough to circulate "stuff" and water and letting it sit for X # of hours and then re-hooking everything up correctly and flushing it out. Is this effective? <br />Thanks
It darn sure can't hurt anything! I'm not sure which to use though.........
itstim
Thanks RatFish...anybody else ever tried this?
itstim
Anybody know what kind of "stuff"?
RatFish
I never tried it.
tommays
well on a car the stuff used to every year before winter<br /><br />but on a boat there is so much rust i have only seen it done by takeing off the parts and haveing them done in a tank usally only the heads would worth doing if the block is that bad it would be hard to make all the labor worth it<br /><br />tommays
itstim
Anybody ever done this?
Dunaruna
Did mine about 2 years ago: engine out of boat, removed circ pump, thermostat and core plugs (all of them). Stuck the end of my pressure cleaner in to every available oriface and blew the rust and crude away, even used a small pick to loosen the stuff that sets like concrete. Chemicals won't budge the hard stuff.<br /><br />Aldo
