knot-a-clew
Thread starter- Joined
- May 31, 2004
- 4
"87 4HP Mariner. Engine pumps water when cold, but flow diminishes as engine heats up. When up to full operating temp., flow of water from "pee hole" becomes a mixture of spray and steam. If I shut the engine down, I hear the sound of air/steam leaking from someplace to somewhere as the pressure equalizes from higher to ambient. Once the sound stops (pressure equalizes) I can restart the engine and it will pump water for a minute or less, then the water flow diminishes all over again. No visable signs of a leak when I try to observe with the engine cowl off. What am I overlooking. Is there a pressure relief valve built into the cooling loop that is stuck closed, creating a back pressure on the water pump. That is exactly the way it acts. I have replaced the impeller, taken it apart to confirm that I did it properly the first time, reinstalled; cleaned the tube in the leg, run a wire through the outlet...just about everything I think of. Any ideas out there
